1 - 20 of 22 Posts
NOT AN ADMIN!!
i hear that, those are the only ptc's on my truck and its only 1/8 line so its not that bad, i wouldent use them on anything else though.
Got Stones????
yeah i have some dual needle easy street guages both of them allready had the barbed fittings for 1/4 line....im gonna take them off and use 1/8" so the wires wont be too messy since space will be an issue in the pillar pods...y2k xtreme is sending me the PTC fittings for the 1/8 line for the guages and also the PTCs for the 1/8" line where it comes off the T in between my valves.....anybody had any leakage with 1/8 gauge line and PTC's?????
Afterhours Admin
No, those barbed fittings are not made to slide the 1/4" line right over them. If you buy the guages from matt @ gauge, he will supply you with gray adaptors where the 1/4" line end is a PTC and the other end is the correct size for the barb, and you push that on there and it locks it in tight.
I have never used them, I have a big pile of em tho, for 2 reasons. 1) I like to mount the guages in a pillar pod or other tight area, and theres no way/reason to run 4 pieces of 1/4" line up there. 2) With the adaptor on it the assembly becomes very long and cannot fit in many areas.
I always pull the barbs right off and slap 1/8" PTCs onto the ends. Lemme tell you that I have had like 98% success rate with these 1/8" PTCs I get from Larry. I got some 1/8" compression fittingsfrom my local hose shop and most of them failed within a week.
If they look cheap to you then dont use them, but I use PTCs on almost every setup I do without many problems at all. late..
Bolt-On Body Dropz
Barbed fittings shouldn't leak, put a hose clamp over the end of them and you will be just fine. Before I upgraded to electric valves on my truck I used to run barbed fittings and it was alright.
I have gotten all my gauges from matt, and never recieved any of those..
1 - 20 of 22 Posts
