Looking in the LMC catalog, it showed a gas tank skid plate. Mine has the front shield but not the skid plate, so I was wondering what it looked like and if I thought it would be worth looking for at the junkyard.
justr a heads-up, the typical tank shield's made of PLASTIC
Let me go check mine. I have 92 4x4 with all front skid plates being made of aluminum. Haven't looked at gas tank but know there is a plate there also.
I'll get back to you if I don't forget to check.
I know mine was plastic on my '88. Not sure how it would rot the tank unless the LMC one doesn't have the holes in it like the original.
If I were you I would make my own. Its alot cheaper and you can customize it however you please. I have made a few in the past out of diamond plate and they came out really well. Just make sure you cut some kind of holes in the metal every few inches, to drain any water that might gather between the tank and the plate.
