1 - 12 of 12 Posts
maybe ill add one later
how hard it is to run it almost empty and see how much it takes to fill it up? should be obvious that if you are almost empty and it takes 15 gallons to fill..then you have a 20 gallon tank
Rarely goes over 20mph
i found out filling it full and running it to half tank, came out to 7-8 gallons, this last one was 10 gallons to go from topped off to 1/4 tank.
theres a big diffrence, if its tiny, its 13g, if its big, its 20g, just put 7 milk jugs under there and thats how much of a diffrence it is
look in your glove compartment and see if theres an option tag if so look for nk2 if it has nk2 on it you have a 20 gallon if not then you have a 13
"Phat"boy
did the blazers run the same size in gallons, just not dimensions?
1 - 12 of 12 Posts
