C.L.I.T Commander
i know! and if you look at the "testing" apparently ford motor co did two emissions tests, one using a chrysler and another using a VW. how much #$$%^# sense does that make??
C.L.I.T Commander
can you put that in english?
the clippy thingy that clips over the cylinder one spark plug wire and lets the timing light know when to flash...2.2s dont have the need, you just rewind the rubber band :D
I BURN THINGS
so if you put one of those on the fuel line, it will do the same thing?
C.L.I.T Commander
Discussion Starter #8
It will probably do as much! paint it yellow and get an additional 5% hp gain!
"Old School"
depends on the yellow - School bus yellow will allow for more torque
