1 - 1 of 1 Posts
NuAge007
Oki 1st question regarding 1994 Jimmy SLE ...
how do i check the fluid in my clutch ... ?
Origianly the truck was 4wd / AUTOMATIC. Now it is 2wheel Rear with Manual Transmission. when the torque increases in a gear ( i use torque loosely ) there is a buzzing sounds that radiates from the actual stick shift. Usually only hear it on higher speeds. > 60mph or at the top end of a gear.
is this low clutch fluid or something else ??
-Bringing the BIG BOX back in style-
NuAge007
1 - 1 of 1 Posts
