1 - 20 of 20 Posts
1992 Chevy S10 2.8L 5 Speed RWD
Just had a fuel pump go out on me for the second time in two weeks. This is the third time I have lost one, the first time would be sometime back in late 2019.
I can't say how many miles I had on that older one, but this new one I just replaced has a bit over 800 miles. I replaced it in the middle of a road trip.
Been driving fine since I replaced it, no signs of anything wrong. I am thinking it has to be something electrical causing my issues. Maybe a short or something.
Advice is appreciated, thanks in advance.
1992 Chevy S10 2WD
2.8L 5-Speed manual
1992 Chevy S10 2WD
2.8L 5-Speed manual
Hi Resistance from corroded ground and or fuel path restrictions likely causes of electric fuel pump early demise, other than junk new parts........
· Premium Member
· Premium Member
Autozone pump
That tells enough, I totally understand NEEDING it now though.... Willing to bet 95% of us have been there.
Discussion Starter · #9 ·
Just finished installing another Autozone pump (Delphi brand). Will just have to see how long it will last me. Inside the tank is pristine, so I can't blame that. The wire harness inside the tank may have been a bit loose from before.
Back up and running for now at least.
Thanks all
· B4U Task Force
Thanks all
Just to be clear...you installed a Delphi pump that you bought at Autozone.
· B4U Task Force
These days, it's like, "Which factory in China made it?"
I feel there's a big difference between an aftermarket designed and built product, and a brand name...such as Delphi product that is built to their original/oem supllied specs. Everyone complains about Chinese parts, but are too cheap to spend the extra on Made in America....which isn't a guarantee either.
I have a relative who's worked with Chinese manufacturing, and his take is that the Chinese are perfectly capable of making a quality product -- if you pay them enough. Their attitude is that they'll make inexpensive crap for you if that's what it seems like you want.
· Premium Member
Compliance with, and adherence, to the OEM specs (or any other for that matter) can affect a part's quality/ durability/ longevity, wherever it's made (domestic or overseas). The manufacturer's QC plays a big role in that regard. A small 'variation', 'interpretation', or 'alteration' of the specs, can have varying degrees of outcomes, rarely (if ever) resulting in a benefit. That's a distinct possibility for OEM or aftermarket products. And, I've come across parts that were OEM (GM & others), but had inherent design weaknesses, and/ or degraded quality due to "value engineering" for cost savings of production.
· Awww..you ain't got shit!
1984 S-10. Modified
Autozone both times because I needed it ASAP. Like Pete said, could just be a crap part.
This isn't unique. Most all of these parts come from red China now. They are junk and substandard, but there a varying levels of substandard junk. Autozone's suppliers seem to have the worst junk of all. A friend of mine and I were discussing all the part failures coming from "the zone". I seem to have better luck with the ones from Advance (better substandard junk).
1984 S-10. Modified
That doesn't describe me. It's gotta be an insane price gap before I won't buy a USA reman or new part. If it's available, it's worth the extra scratch. Plus it helps the country and local economy. Even on my foreign Toyotas, I buy factory parts because I know (generally) that they're way better. Like the clutch on the 08 Scion xB. I ponied up for the factory units rather than take a chance on some cheap aftermarket one. Was an extra hundred and change. The factory one lasted 216k. Lets go with that again! Why gamble with a repair like that? There would be no savings if it fails for sure getting an aftermarket part that fails or doesn't last like the factory one.
On the S-10? Ever buy an aftermarket heater core? Holy Toledo! They'll sell you something that doesn't have a chance in hell of fitting. 1/4' too thick....too long, bent incorrectly. I ALWAYS go OEM on that. Struggling with that garbage is not worth it!
1 - 20 of 20 Posts
