where the hell is the fuel pump fuse???
It is probably the same place mine is.
Try the lower left blue 15amp fuse #9 maybe, might be labeled as EMC-B. On mine it is for the fuel pump and part of the computer. It also will clear stored codes when removed. Try looking in your owners manual if you have it. What is your problem? Don't forget you also have a fuel pump relay. Don't know where yours is buy mine is on the firewall beside the brake booster. Hope that helps.
thanks, when i was installing my holley tbi it said to pull the fuel pump fuse. but i didnt, i knew about the relay too. thanks
anyway
