Ok i have 3 fuel lines coming up through the frame in the engine compartment. I am wondering what do do with them. I know the big one (closest to the front of truck) is for the charcoal canister but i am not going to run one on the 350 so i plugged the line. One is the fuel supply so that one goes to the mech. pump but the other one is a fuel return line do i need that or can i just put a plug in. I am running a holley 600 4bbl carb if it matters.
lines
The large line gos to your pump,The return line you can plug.The line that goes to your charcoal filter is a vent ,I wouldnt plug it,I ran mine to the back of the truck and put a vent valve like the one on the rear axle on the hose,Keep it away from the cab to avoid gas smells .I guess you got your pump on???
yep got the pump on, relocated the steering column over a little then moved the motor a little to the drivers side. worked good.
