New problem. Seems that when I was jacking the trans up and down and side to side for my motor replacement, I smashed the fuel return line and now I have a :censor: leak. What is involved in replacing the lines? Can I do it from underneath? Please dont tell me the motor has to come out again.
i saw what you did there!
is it TBI? what year?
need info here
if its TBI then you can patch with regular fuel hose and hose clamps and be perfectly fine
if its plastic nylon black tube line then hmm... well... im not sure what you can do there short of replacing entire line
It's "Neanderthal"
The fuel in the return line is not under any real pressure, so you should be able to patch it.
