1 - 13 of 13 Posts
Is it ok to mount a filter on the suction side of a mechanical fuel pump?
General rule of thumb is do not restrict the suction side of a pump. If you do it can cavitate or restrict flow and that can/will cause air bubbles. You want the suction side to be flooded at all times. I am not talking about the nylon sock or screens that are on pump pickups.
is a fungineer
You're going to get both sides on this one.
I don't see it as a problem, and if I have any trash coming through the fuel system I'd rather have it get caught before the pump than after.
Cavitation is my main concern.
That's what I was thinking, I'd rather see it get caught before the pump. I called summits tech line and they said it was ok; which doesn't mean very much.
is a fungineer
That is usually why they have a mesh sock or screen prior to the pump with the actual filter after the pump.
That's fine, but if that was good enough why would you need a filter at all?
I'm going with a fuel cell, do they have a filter on the pickup or anything like that.
That is to catch the larger pieces before they go in to the pump. The filter is there to stop the finer particles from clogging the injectors.
I am not here to start an argument. I am merely saying that most systems are designed with the filter after the pump. You, I am happy to say, have the freedom to design your system any way you like.
Discussion Starter · #11 ·
I've talked to "old timers" who say cavitation will be a problem. I talked to summit and jegs tech reps and they both say it's fine. I'm going to mount it in the bed bythe fuel cell for easy access.
Longbeds FTMFW
I know you guys are talking mechanical pumps, but i went through 3 electric pumps in a little over a year. Finally I got so fed up with it i called the company and they told me I was having pumps fail because of the filter I was running before the pump. I was told that the pump is meant to "push" fuel and not "pull" fuel, and it was causing the diaphram inside the pump to fail.
My setup was cell-filter-pump-filter-regulator.
I was also told that the foam inside the cell breaks down over time and can wreak havoc on fuel systems...
1 - 13 of 13 Posts
