Certified MASShole
Ok first ? is the sending unit 0-90? i have found a few cells that come with this gm sending unit. also what kind of pump would i run??? inline, would i need a regulator. i searched some posts and didnt find what i was looking for. ne help would be great. i need to know what to buy with a lil xmass cash.
Blown ex ***
i put the hole unit in my cell. though it was modified.
Certified MASShole
put a hole where and for what??? my stock pump is really loud and the bed i am gettin, the gas door is shaved. how much work would this bed to put in my truck for now im just gonna bolt it to the bed floor but later i hope to weld in the rear frame and put it there.
Blown ex ***
i have mine where the spare tire used to be. it was a good bit of work to make it work. but there are lots of different ways to do it. so you will have to figure out what you can do.
i meant to say "whole" not "hole" , damn "w" key, doesn't work sometimes.
Jess, So you were able to put the oem fuel pump in an aftermarket fuel cell like drag racers use? I'm just trying to make sure I'm reading this right. I assume the fuel cell has a port for the return fuel line. Thanks!
