UNDER CONSTRUCTION
a friend of mine has a 15 gal jegs fuel cell wit gm sending unit that he wants to sell to me. i would like to use it for my other s dime its a 2000 with a 2.2l i'm going to install it inside the bed near the cab. wat do i need to install/ wat do i need to remove from my existing unit. anyway i can use the stock lines. any help would be great.
You will need to make sure that your pump and pick up will work with that tank or make sure you have an alternate source of getting fuel to the motor at the correct PSI and volume. Also make sure that your emissions (carbon canister) will hook up to it
