my passenger side goes up a bit higher then the driver when the psi is the same..the lines r all the same length is it cuz the cups are a lil different in sizee
Banned
sadexcuse4s10 said:
the drivers side is heavier man, gas tank, steering, brake setup, all that shit is on one side of the truck
Not to mention the driver.
And the the only thing to counteract the weight is the battery.
Glad to know that somebody other than me knows that the gas tank is not the only cause of the chevy lean.
To correct this problem, just bump the driver left side up and add a bit more pressure to level it out.
Welcome to the realm of air ride suspensions... where you will never have the same pressure at the same height in any two bags... :haha:
Sometimes it just won't happen... just somethin you gotta get used to.
