choppin on twankies!
ok i have 2"spindles on top of zq8 with 20s i need something to make it a lil stiffer in the front i ahve bell-tech nitro drop shocks and factory springs what ya think i could do to make it a lil stiffer? thanx
if the truck is a 2.2, then you could order a set of 2" V6 drop springs, that should keep it close to the same height, but if you install the springs, and the front sits to high, then you could trim a little of the spring off to bring it back down. also a belltech nitro drop active shock, which is stiffer then the regular belltechs might help a little.
thanx
