They're about yay big...
oh wow. thanks. mine are gone gone then.They're about yay big...
My front stops are pretty ragged after 26 years. No worry about the rears since the stops and brackets have been cut off for 24-25 years... 😂 .15956547 is the AC Delco part number for the ZQ8 front bump stops. I found them at Rockauto in 2020. I prior to them I tried the Dorman equivalent but they didn't last too long. Like Mostizzle said they are an integral part of the suspension. The rears are also unique to the ZQ8 trucks, but I haven't been able to find any.
get those done asap if you have unobtainium bilstein shocks. the $14 delcos work fine but the fun factor is severely diminishedMy front stops are pretty ragged after 26 years. No worry about the rears since the stops and brackets have been cut off for 24-25 years... 😂 .
It hasn't been an issue so far.get those done asap if you have unobtainium bilstein shocks. the $14 delcos work fine but the fun factor is severely diminished
I'm at 2/3. I've never bottomed out...front or rear. Not sure how a $10 part will prevent $500 in damage to hard to find parts. Not even sure what those hard to find parts are.My rear rear bump stops rotted off probably 5+ years ago. I managed to save what was left of one for dimensions. I'm thinking of trying some from a full size gm at LKQ since they are similar in length and density. I'm also only ZQ8+ 1" drop with the rear setup, so not as low as your truck is.
It does sound like I'm telling you how to get rear bump stops, but really I was just generally stating a possible solution for replacing the rear ZQ8 stops for anyone. I don't think bump stops would be beneficial for you with your setup. You're 2/3 lower than stock ZQ8, where I'm just 1/2" front and 1" rear, so my truck could possibly benefit from stock parts.I'm at 2/3. I've never bottomed out...front or rear. Not sure how a $10 part will prevent $500 in damage to hard to find parts. Not even sure what those hard to find parts are.
I don't think the rears contact often, but I did haul 1,200 - 1,400 lbs. a couple times in my bed the first few years I owned my truck and it was riding near/on the rear bump stops those times. It wasn't too smart on my part to load that much (I believe 800 is the factory limit) but I know better than to risk it now. So just ask Mike and the gang to hop on a scale before you guys party!Exactly. The whole cast of Mike and Molly(along with my self and groceries for the gang) could sit in/on my truck and it wouldn't touch the bump stops. The front end would just sit on the ground and the pumpkin would be touching the bed floor.
The energy ones you posted will be much much harder than regular factory or the zq8 ones which are even softer.
Not at all...this was just for comparison. I don't carry heavy loads.It does sound like I'm telling you how to get rear bump stops, but really I was just generally stating a possible solution for replacing the rear ZQ8 stops for anyone. I don't think bump stops would be beneficial for you with your setup. You're 2/3 lower than stock ZQ8, where I'm just 1/2" front and 1" rear, so my truck could possibly benefit from stock parts.
zq8 shock & spring are hard to findI'm at 2/3. I've never bottomed out...front or rear. Not sure how a $10 part will prevent $500 in damage to hard to find parts. Not even sure what those hard to find parts are.
