1 - 2 of 2 Posts
I think my next job is front brakes, have a good wobble/shimmy when braking so.. I'm going to get rotors and pads from the parts store, do I need to also worry about wheel bearings or anything else? (You can see from the time that I am posting here instead of consulting my manual, just thinking about it for when I go to the store tomorrow.. :) )
started as a 4X4 anyway
I would inspect the bearings when you remove the rotors. If they look good then just repack them with grease and reuse them. If a bearing is shot you will know when you pull them. When you pull your slider bolts out of the calipers make sure you clean them off VERY good and throw some grease on them before putting them back in. If they are rusted or pitted buy new ones. They are cheap.
1 - 2 of 2 Posts
