i have a 2000 s-10 extended cab with a 4.3 auto
if i was to get a new frame would i have to get one for a 2000 or what years would work
and would i have to get one with a 4.3 or can i get one with a 2.2 and switch motor mounts
and would i have to get one that had an auto or could i just switch the crossmember out
and i have the carrier bearing crossmember too for the drive shaft
how much do frames usually run for at like a junk yard and has anyone priced one from a dealership. i heard around 1-2 hundred from a yard
thanks
-Jim
VVVthat thing is deadVVV
anything from 98 and up should work i believe. they were slightly different in a few ways 97 and earlier. you can get a frame that had a 2.2 and swap motor mounts. you will have to swap tranny members and carrier bearing members though
