ok my buddy on his 2001 has the bracket on the axle but not on the frame. so hes buying the bracket that goes on the frame and im gonna order him a doetsch tech shock that will be the hop shock. the factory hop shock is like 130 each but what im gonna do is measure from center bolt to center lets say is 10 inches. order a shocks that is 10.5 inches fully extended. ill try to find one that has a lot of pressure in it i think doetsch tech has 180 psi. then we will see if it helps. if it works out ill get back to you guys and tell you the shock length and what shock part number it is from summit. should only be 30 bucks
tony
tony
