First off, what is meant by "2 piece"?
Secondly, i noticed the 17's and 18's only come in 8" wide. What kind of offset do I need so they rub the least and don't look ridiculous sticking out? Also, with say a 255/X/18 tire...what X value will keep the closest to stock diameter?
body dropped
2 inches of backspacing. I'm running 245/35/20. As for your X value, just plug some numbers into the numerous tire size calculators there are on the internet. 255 may be a bit wide for you 8" wide rim. try a 225 or 235. "2 piece" means that it's made from 2 pieces and then welded together.
