Registered Loser
What is the proper procedure for disconnecting a battery in a two battery set up?
Does it matter if there is or is not an isloater(sp)?
I know in a single battrey system you dissconnect the +positive first then disconnect the -negative.... reverse for installation.
But I can't figure out the two battery procedure
Thanks guys!
uhmmm... always disconnect the negative first, on two batteries, it would be negative, negative, positive, positive, reverse for installation
