The ignition switch in my 2003 has been getting progressively worse. First I just had to jiggle the key a bit to get it started, now I have to jiggle it a lot both when started and when removing the key.
Is there a fix for this, or does it require a new ignition switch?
If a new switch, any tips on where to get it?
There is a fix, the ign. cylinder has to be removed and a little bar pried off.
I did this on my 2002 following a YouTube, a 2003 is probably the same?.
Then almost any similar GM key will work so it's not very secure.
A new cyl could be installed once the old one is removed.
A new ign.cylinder will have a different key
Thanks
Randy
Registered Hoosier
More often than not, the cause is a worn key, or a copy of a worn key. I had several keys cut for our work trucks at the local dealer. Only one of them still required the wiggle jiggle to start it. Go to a dealer or locksmith that will cut it from the code.
Banned
Do the 2nd gen ignitions get like the 1st gen where you don't need a key ? I for one love that, my truck is WAY too rusty to be stolen LOL. Almost every chevy I have owned you didn't need a key, its like a chevy thing I think lol.
Cut a key from the factory code. It's work down and the tumblers aren't being engaged properly. If the key is rounded on the edges then it's like trying to pick a lock, jiggle jiggle you're in. The factory code will be needed but most places charge like $20 for a regular key. Just did this a few days ago.
