1 - 11 of 11 Posts
Needs a new license plate
I have a 98 S10 and I'm dropped 2/3 with Belltech spindles and leaf springs.
I was wondering if 20x8.5" wheels with 12mm offset will fit?
will 255/35/20 tires fit without rubbing or will they rub when i turn all the way?
I have a wheel fetish !
depends on what offset the wheels have ?
i had 20x8.5 with 10mm offset and 255/35ZR20 and they lightly rubbed the frame at full turn.
how much are you lowered?
because i wanna go down to 3/4 if it works
2 inch drop spindles and 2 inch blocks, that is ontop the zq8 suspension (another 1.5 inch )
Banned
hey man don't mean to whore your thread but,,i read on here that 2" drop spindles bring the wheel out like 1/2" ? will that stop the rubbing at full lock ,on my 00x with 20x8.5 offset is 8 back spacing is 5
The pimpdizzle
When I lowered my truck after I got my 20s the outside edge of the tire would rub in the fender when hitting bumps or when turning sharply. Thats with a 2/3 drop on 255/35s with a 14mm offset.
Discussion Starter · #11 ·
here's how mine turned out so far...
1 - 11 of 11 Posts
