1 - 10 of 10 Posts
Moving Violationz NE Member
looks good. Im finally upgrading to 1aut power cable The biggest you can go. I think it's the same as your but purple and the ground is silver.
looks good whoever did the install did a good job
HOW MANY WATTS u runnin????
Flippin a Blazer hurts
Let's see.... The Thuder 1000 D is normally rated at 1000 watts at 12.5 but MY birth sheet for My amp is rated at 1211 watts at 12.5. I've got the 3 12ohm subs wired in parallel for a 4 ohm load so I THINK about 275-375 per sub. Then I've got the seperate 8-gauge cable for my DEI amp which is pusing the components.:idea:
I WENT TO THE PLACE that does all my work for me and they told me After I hook up my new RF 5002 amp (birth 702 watts)
and my kickerzr240 and my 2 rockford 12 inch DVC I will be right at 1500 watts in my reg cab X
once the amp is hooked up with my new wire and ground I will get it tested and post the meter readings.
your system looks awesome by the way
not inlcuding my doors and dash speakers. I need to go have it tested soon.
1 - 10 of 10 Posts
