1 - 16 of 16 Posts
Super Moderator
Info supported by www.alldata.com
Vin 4
1994
3,1,4,2 coil left to right, block front to back 1,2,3,4
Vin 4
1995, 1996
4,1,2,3 coil left ro right, block front to back 1,2,3,4
Vin 4
1997,1998,1999,2000
1,3,4,2 coil left to right, block front to back 1,2,3,4
Vin 5 Flex Fuel
2000, 2001, 2002
Vin 4
2003
Vin H
2003
1,3,4,2 coil left ro right, block front to back 1,2,3,4
damned 4banger
my coil packs are set up the same way, but my wires dont run the same as yours there
Super Moderator
gwad v2, it still runs of 3,1,4, but start with 2, but thanks for putting up for future reference though for other 1994s
NOT AN S10
That's odd that an all electric S10 (VIN H) has a spark plug firing order
hmm, interesting. 1+4 are always going to be paired together, allong with 2+3. how you put the wires on shouldn't make a difference as long as you pair the cylinders to the right coil pack.
Firing order will be 1 - 3 - 4 - 2, with wires on the coil pack being 1,4,2,3. You can switch 1/4, or 2/3 on the coils.
Vin 4
1994
Vin 4
1995, 1996
Vin 4
1997,1998,1999,2000
Vin 5 Flex Fuel
2000, 2001, 2002
Vin 4
2003
Vin H
2003
Thast the wrong coil sequence for the flew fuel. It reads (as I have done this for 20 years on my 2000 s10 2.2l. 1,4, 3,2. Also how do I know? I do one plug/wire at a time.
It's mostly BS
Besides digging up a prehistoric thread, you got the firing order wrong. The correct order is 1342.
And yet youre still here to give out the wrong order. I just did my order for VIN 5 and works perfectly and have so every 3 years for the last 20. Carry-on....
Ok...throttle back some...
It's mostly BS
Sorry but 1,4 and 2,3 cannot fire after each other because of the lost spark ignition system they are on the same coil and fire 360 degrees apart, not 180 degrees like you have. You have something wrong with your numbering on the coils.
time to get cereal
What? Each coil fires twice per cycle. That is how you get a "wasted" spark. Not sure where you're getting 360 degrees from.
It's mostly BS
I'm talking about the cylinder firing, not the coils. The coils fire to both of the companion cylinders 1&4 and 2&3 every 360 degrees of crank rotation. On a non waste spark system, the coil fires every 720 degrees to each cylinder.
time to get cereal
Oh, ok. Got ya.
1 - 16 of 16 Posts
