P
Guest
Well it finally happend my S12L7 apparently crunched my crunch amp (400.2) so now all i have is an LA sound 150 x150 i barowed from my friend to push my boston acoutics..anyway im about to get some money in 3 to 4 days and im thinking about investing into the kx 800.2 from kicker and bridging it so it sould feed about 800 watts to the S12L7. Then getting another S12L7 and hooking up another 800.2 to the next one....cuz the only amp kicker makes is a class D mono 1200watt...so would that mean i can only hook up one s12L7 to it? and even if i could id also have to get another s12l7 so the load wouldnt kill the one i have now. ANY advice is welcomed. Thankz! -Corey
BLAZIN SADDLE
(PhatSS10) If you like KICKER and want to stay with KICKER run 2-12L7's and 2- KX400.1 or if you like it loud get 2- KX600.1 both amps are CLASS D's and they both will do the 12L7 right. I think the KX800.2 is rated at 4 ohms bridged. I think the CLASS D's at 2ohms are a better match. I'v heard the KX600.1 and I think thats why KICKER did not make a 800watt CLASS-D, The KX600.1 CLASS-D pumps the subs pretty GOOD. :headbang:
______________________________________________
02 WHITE BLAZER X
1-Leather seats and top door panels
2-GPS alarm
3-Billet Bowtie
4-255/45/18 Pirelli Zero's on HALO rims
5-Boston Acoustics speakers in doors/dash
6-Pioneer 6x9's in the back seat area
7-K&N GEN II
8-FlowMaster 40series with 2 1/4 pipe Magnaflow SS tip
9-2/3 DROP with Belltech Spindles and Blocks
10-Poweraid Spacer
11-Removed MAF Screen
12-JL amp and one 10” JL subwoofer
13-SS mirrors WHITE, matching handles
14-Shaved Emblems
15- HPPIII
And a list one mile long
P
Guest
but looking at money would it work as well to get a 1200.1 from kicker with another s12L7?:burnout:
BLAZIN SADDLE
I think if hooked up right the two KX600.1 can be a more powerful clean SOUNDING system than one KX1200.1 the 1200.1 is said to be rated at 1ohm and you may over work the amp with two S12L7's. Check prices if you can get two for alittle more than one DO IT!!!!! If one (KX1200.1) fails your screwed. If one KX600.1 fails your still jamming with the other one. room may be an issue, the KX1200.1 is I think only 5 or 6" bigger with the shoud so two KX600.1's may take up some room. I hope this helps :thumbup:
02 WHITE BLAZER X
2-GPS alarm
3-Billet Bowtie
7-K&N GEN II
10-Poweraid Spacer
14-Shaved Emblems
15- HPPIII
