8
89s10-350
·Guest
Ok I've finally decided what I want I just need to make sure it works.
I have a first gen.
For the Back:
Eagle 212's 17x9.5 with a +19mm offset.
2??/45-17 Tires
For the Front
Eagle 212's 17x8 with a +14mm offset
225/45-17 Tires
Will this all work with no rubbing after a 4-6 drop? And what tire size should be in the back in order to work wih no rubbing? Also will the 9.5's fit in the back? If not I'll go with the 8's. I want the 9.5's because I have the horsepower to loose the traction.
I have a first gen.
For the Back:
2??/45-17 Tires
For the Front
225/45-17 Tires
