I was wondering if you were to fiberglass certain pieces, can you just put the resin directly on the pieces, or do you have to have a cloth there? From what i have read though, you lay the glass, bondo, primer, paint, then clear coat it. If i have missed anything, tell me so i will do it right later. Thanks
:drunk:
I think you must sand before, to get the tecture to the point where the fiberglass won't just fall off. And you don't ned cloth unless your going to cover or mold two things together, I would just put resin, glass, sand, bondo, sand, sand, sand, bondo(if needed), sand, primer, sand, then paint. I'm drawing a blank whether if you must sand after primer, but someone else can tell you, I just to tired right now hope this helps, key to fiberglassin is sand woooo
-Mike
