When converting a 4.3 to carburated in a originally tbi truck, do you need to get a new throttle cable bracket--the edelbrock one? I have a 1" spacer on if that matters.
In comp cam's catalog, for all the cam accessories it lists 2 part numbers: 1 is the "premium choice" and the other is standard, whats the difference between them for lifters? #850 is standard and #875 is premium.
What length valves do I need to step up to 1.6/2.02? Do I just order the same spec valve as stock but different head diameter?
Whats the stall speed of a stock 700r4 behind a 4.3?
