I recently acquired a factory fog light switch panel for my 98. I don't have factory lamps on my system but do have aftermarket. My question is this. Does anyone know what the pinout on the harness is for the factory switch? Mine aftermarket switch only has 2 wires to break the connection and I would like to wire them up to the factory switch. Is this possible? The factory switch has 4 wires.
Discussion Starter · #2 ·
Doesn't look as though this forum gets much attention but if anyone reads this I found out a little more info.
I took my dash appart and found that my truck is wired for the switch. The harness is there but it isn't plugged into anything. So I can just plug the new switch in and I am good there. My question now is does anyone know where the wiring is in the front end for the lights? Is it with the headlight wiring?
there probably is tails there somewhere just zip tied up out of the way.
Do you know if the tails would be closer to the turn signals or lower than that? I think factory "fog" lights are next to the turn signals aren't they?
Premium Member
i bought my factory fog lamps in a kit from the chevy dealership I was at... it came with the airdam, foglamps and factory wiring with a relay, thats why there are four plugs on it
Project ZO6 S-10
Just go to radio shack and get a multimeter they are very useful.
you can test the switch.
