I disagree with the hiflow cat not making a diff. At least on 1st
Gens. I had a factory cat and though it did it's job, the back
pressure came out to almost 2 to 3 #. My ride runs good.
Not as good as it could but it never ran fat or lean save for
an idle misfire sometimes. I stay on it. The orig cat had almost
80,000 on it. I could tell from a smog dyno test it wasn't using
all the o2. In fact it was at 2.43%. I had a Catco hi flow cat
that I had been waiting to put on, just never got around to
it.
I installed the cat, using the same muff. A flow delta 50 and
the same tubing, 2.50 out. After I got the new cat in the sound
was much deeper and I felt it was flowing more. I did a back
pressure test and it came to 1.50-1.70 # at 2000. I then did a
another dyno run and found the new cat was using o2 with
a leftover amount of 1.18%. In fact from having a an engine
that ran HC's at 99 ppm to went up to 123ppm with a o%
CO. So as far as I'm concerned at least on my ride the hiflow
worked and I passed a state of Ca test only smog test.
As far as a muffler, there's better flowing muff's out there than
a Flow. Dynomax Bullets, Magnaflo muffs, and Hooker Maxflow.
However Flowmaster has sold a LOT of muffs, so they must
be doing something right..I have two Flows sitting in a shed
along with a Gibson muff..It to me, flowed the worst. Just a bit
up from the stock muff, I felt.
I'm running a Spintech chambered muff. It's coming off this week
for a Maxflow. I want to go from chambered to a straight thru
design with some quiet to it..However exhaust sounds and
performance I have come to believe, are best left up to the
owner..No one seems to have a definitive favorite. I've
heard good things about Ravin muffs, that's discussed over
at the exhaust forum..Lots of info over there in the present
and past pages..
