philly d from canada
Hey all..I have a 84 blazer with a 2.8l and one of the studs is busted off so id like to replace them all. Went to my local parts store and they have no clue so im wondering if there is a online place that sells them that may be cheaper then the dealer..phil
Super Moderator
Dealer, shouldn't cost much
4x4 v6 blazer
they are cheap enough at teh dealer. Also, they should be bolts, not studs.
Depends on were it is, most of them are bolts but there are studs near the front that other crap bolts to. On the pass side there is a alt bracket (if you can call it that) that uses the top bolt on the front cylinder as a support, I'm pretty sure there is one on the drivers side also but I can't think what uses it.
