Hi again all. Its been a while since I have posted.
Today I'm trying to locate the ERG so that I can clean it. I hope this will help with my rough idle on my 95 sonoma (4.3l). Can anyone help me locate this??? A picture would be fantastic! The darn Hayes manual was useless in this case.
Thanks
Black 95 SS
I am at work or I would go down to my garage and take a picture of the location for you.
If you cannot find it say something and I will get a pic for you later on.
It is located right under your air intake manifold, its in a tight spot, and looks like this...
Thanks a TON ya all!
Pulled it, cleaned it (with seafoam deep creep), replaced the gasket and put it all back together.
I turned the key and Vrooooooooooom!.........Are you ****ING KIDDING ME!!!!!!!! Runs like a charm.
I figure any shop I would have brought it to would have changed the rotor and Dist cap(which I did anyways because it needed changing),coil, wires, plugs, IAC, the "spider" and then maybe the EGR (ya sorry about the typo earlier). In other words, mega $$$
Either way, for $15 (canadian dollars)and a bit of my time, I have my dime running like a top....thanks to this forum!
Once again...thanks a ton ya all.
