1 - 19 of 19 Posts
so i have teh envoy lights in.. but the stay on all the time when my truck is runnin... i have done the fuse thing.. where you bend one prong over, and i have done the resistor thing on the arl in teh speaker grille... any suggestions on where to go now...? thanks
yes, they cut off when i cut the truck off.. i mounted them on the factory brackets like come on the envoy.. mounted to the rad support..
rc guy
When you do an HID set up, you really should do a relay setup. The ballasts for those lights can draw a lot of amps for firing up those bulbs. Its possible that you fused your headlight switch by wiring it into your factory wiring.
Discussion Starter #16
no , i have not yet.. where would i mount the ballest? I just found this out also... in teh daytime, b4 my ARL kicks in.. if i turn my blinker on it will turn the HIDs off.. whats that mean?
They took our jorbs.
the drls only affect the high beams. The envoy hids were the "low beam" bulbs. And i promise you, these are negative turn on ballasts, ask samandjen.
1 - 19 of 19 Posts
