What’s up everyone,
my 85 s15 2.8 won’t idle. I can start it up with my foot on the gas and keep it running. As soon as I stop giving it gas, it dies. The other day I changed all the vaccine hoses because they were old and I figured it could be a vacuum leak. It didn’t fix the problem. I kept it running and started disconnecting things. When I disconnected the mixture controls solenoid, it idled fine. I already replaced the solenoid (it was the first thing I suspected to be wrong). I’m guessing it’s the connector that’s bad. Can someone tell me how to test to see if it’s good or if there might be something else I should be looking at?
Thanks,
Yowakawaka
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
time for a carb kit and a good cleaning
@Jayhawke it runs fine when you disconnect the mixture control solenoid. I think it’s electrical. I have this multimeter but dint really know how to use it. I’d like to test the connector to make sure I’m heading down the right path.
Anyone know what settings I’m supposed to have the multimeter set to, what hole to put the red wire in, and what color to probe what hole with?
I found this website where someone explains that the tip on the inside of the mixture control solenoid Can come off and get stuck in the carb. Here’s the website link.
I looked at the old one and saw the tip was there. I even took off the new one and the tip looks to be there as well. Here’s a photo of both. Hopefully you can see it.
(old)
(New)
I also found this page in the manual about testing the mc solenoid.
I don’t have a vacuum pump to do the test. I was gonna get one from harbor freight but I dint think it would even pump fast enough to do the test. Does anyone know of another way to do the test?
Also, @Jayhawke I think the carbs already been rebuilt. There was some extra carb gaskets in the cab when I got it. I was also looking inside it and it looks clean. I’m guessing this is why the guy was selling it in the first place.
Anything I should be looking at?
