I don't know if anyone has done here yet, but has anyone swapped a supercharged 3800 into a s10/s15 that has a 4.3 currently in it? Will the transmission from the 4.3 bolt up to a 3800 and do you have to change the wiring harness much?
Replacement parts canon barrels are available on Amazon... 😂The LS series of engines are newer, more efficient, and usually more powerful. But... They are a lot more work and expense than a late model 350. For example, all of your front accessories will bolt on to a 350, but you'll need all new mounts and accessories for the LS. The LS won't bolt directly to your current transmission either w/o some adapters.
It's the age old game, how fast can you afford to go? A SBC swap is a lot less expensive.
Note: I didn't say inexpensive.
If your building a DD a 350 is just fine. Every engine swap in the USA doesn't have to be an LS.
Even if the internet and magazines say it's the only way to go.
Before the LS1 came out thousands of S10's got SBC swapped and the owners were happy with them.
Just don't make the mistake of trying to go too old school with a carb and TH350. That's 50 year old tech.
You obviously aren't afraid to be different or you wouldn't have initially asked about the Supercharged 3800.
Rant over.
I just spent another few hundred towards finishing my LS swap.
