Swap to a 4.3 is easy but you will need another transmission since the current Trans would be a 60° and the 4.3 is 90°
You should start your own thread and tag ODS.Threadjack-- So Oldeerslayer, am I right to understand that if I get a 5.3 LS4 I can use my existing 700R4 that is currently attached to my 2.8 block? LS4 only or would any of the other LS versions work? Can I use my existing transmission crossmember?
@Rhotpursuit is right. You should start your own post in the V8 section where I can explain to you why no one has ever put an LS4 in a car or truck with RWD.Threadjack-- So Oldeerslayer, am I right to understand that if I get a 5.3 LS4 I can use my existing 700R4 that is currently attached to my 2.8 block? LS4 only or would any of the other LS versions work? Can I use my existing transmission crossmember?
