oh, and compression checks,
#1=160
#2=160
#3=162
#4=160
#5=162
#6=175
#1=160
#2=160
#3=162
#4=160
#5=162
#6=175
A spry 233,000 miles. I am on that distributor. I was testing the pick up coil and found a bit of slop in the rotor shaft last night. I only have the fuel pressure reving it up. It is not really drivable the way it is running. The previous owner had the engine out at some point It’s obvious by the orange paint and wire routing. So I do t know what the actual miles on the engine may be. I have a video of the slop. I’ll see if I can post it.how many miles? when was the distributor replaced? what is the fule pressure throughout driving?
Use YouTube and post a link.A spry 233,000 miles. I am on that distributor. I was testing the pick up coil and found a bit of slop in the rotor shaft last night. I only have the fuel pressure reving it up. It is not really drivable the way it is running. The previous owner had the engine out at some point It’s obvious by the orange paint and wire routing. So I do t know what the actual miles on the engine may be. I have a video of the slop. I’ll see if I can post it.
Check the PVC valve to see if it's clogged or sticky....either r/r...or spray with some brake cleaner to clean, shake it around to make sure inside move freely...reinstall on vac side and test functionality with your thumb (should snap back and return smartly), then put back in valve cover. Recently was running down a similar problem on a 1994 and turned out to be a sticky PVC valve. I was on the verge of deploying the parts cannon and lucky avoided that cost. Also, cleaning the IAC is probably worth a try (remove, spray pintle and spring with carb cleaner, wipe gently, it's a stepper motor configuration so do not push,pull or twist pintle/shaft -- also make sure the IAC pintle seating area on the intake side is clean too, i.e., more carb cleaner & a Q-tip)-- should also verify proper IAC operation via scan tool.I had an old post about this but it has been so long since i posted about it I'll start a new one. I have been chasing a problem with this thing for awhile. it will surge sometimes and run rough like it is missing , exhaust smells rich. I have checked/replaced the following trying to fix it:
EGR valve-changed
EGR solenoid -changed
plugs, wires, coil, cap and rotor- changed
ICM-changed
MAP sensor-changed
TPS sensor- checked volts
checked base timing
fuel pressure-12psi constant
vacuum (18" until it stumbles and then dips)
ECT sensor-changed
rebuilt TBI and pressure regulator
changed O2 sensor
unplugged evap canister and plugged the port
I ran it with the ESC unplugged like when setting base timing and it did not improve.
What has me convinced it is a timing or misfire issue is that the last thing i did is unplugged one spark plug wire at a time and ran the truck and there was virtually no change in how it ran. #3 cylinder may have been slightly rougher than any other but not much. Perhaps reluctor ring in distributor? No codes and everything on scanner looks "normal" only will throw a rich code every once in a while if the O2 sensor doesn't start reacting fast enough. changing the O2 sensor made that happen a lot less.
Which one?...some have two, one for PCM (located near thermostat housing) and one on driverside engine block (for gauge). I think the PCM ECT sensor provides one of the data inputs that the PCM uses to set the IAC.ECT sensor-changed
In the intakeWhich one?...some have two, one for PCM (located near thermostat housing) and one on driverside engine block (for gauge). I think the PCM ECT sensor provides one of the data inputs that the PCM uses to set the IAC.
I cleaned the entire TBI. I’ll check that PCV before I reload the cannon!Check the PVC valve to see if it's clogged or sticky....either r/r...or spray with some brake cleaner to clean, shake it around to make sure inside move freely...reinstall on vac side and test functionality with your thumb (should snap back and return smartly), then put back in valve cover. Recently was running down a similar problem on a 1994 and turned out to be a sticky PVC valve. I was on the verge of deploying the parts cannon and lucky avoided that cost. Also, cleaning the IAC is probably worth a try (remove, spray pintle and spring with carb cleaner, wipe gently, it's a stepper motor configuration so do not push,pull or twist pintle/shaft -- also make sure the IAC pintle seating area on the intake side is clean too, i.e., more carb cleaner & a Q-tip)-- should also verify proper IAC operation via scan tool.
LOLZ 🤣before I reload the cannon!
this post has turned into my personal sounding board but, i think the PCV has made it turn the corner. Besides the first time I ran it afterwards and it throwing a code, after the diagnostic mode it has not surged or smell of gasoline bad . I think you may have nailed a large portion of the problem. It still vibrates but I dont think that is a related issue. I need to check the dampner and motor mounts. I stopped messing with it for a while and started putting in my jungle website radio and I noticed that my dash temp gage would go up and down with the engine off. might be something else to look into.LOLZ 🤣
Outstanding.this post has turned into my personal sounding board but, i think the PCV has made it turn the corner. Besides the first time I ran it afterwards and it throwing a code, after the diagnostic mode it has not surged or smell of gasoline bad . I think you may have nailed a large portion of the problem. It still vibrates but I dont think that is a related issue. I need to check the dampner and motor mounts. I stopped messing with it for a while and started putting in my jungle website radio and I noticed that my dash temp gage would go up and down with the engine off. might be something else to look into.
