When i first start the truck from a cold start my truck makes a sqeaking/sqealing noise when it starts up and gets faster when the rpms increase. After about 10 mins it will go away. Also when the rpms increase to around 3k-5k it makes that a ticking/sqeak noise i do believe is the same. I had replaced my idler pully already which was really bad, along with the tensioner i though was possibly hitting on the stop making a the noise and possibly bad bearing in pully, and my alternator. It sounds like its coming from the middle of the motor from around the crank by the water pully/clutch fan. Anyone know how i can try to figure this out other than replacing everything? Thank you
i saw what you did there!
uf you poke aroune with a wooden stick or broom handle short length you can pinpoint whats making noise, with an ear on the end of it.
Im reading in the Haynes manual that their is fluid in the clutch of the fan and it takes time to get though out it when it warms up? Thats when it goes away when it warms up lol
