Since you have a TBI 4.3 with the VCM under the hood, putting a 2000 Vortec 4.3 in is physically close to a bolt in. You will have to bring along it's computer and wiring harness. The wiring won't be extremely difficult if you are an electrician or a vehicle tech well versed in doing swaps. For most folks, tho, it could be overwhelming. You might want to talk to CPW about what you want to do. They can probably build what you'll need for around a grand. There are maybe half a dozen guys on this forum who could do it. By the time you pay their air fare and what they'd charge for a week of their time, CPW will be less expensive. You can't simply unplug a computer from one truck and just plug it in another. It has to be done 1 wire at a time while having an overall plan in mind. Then all you need to do is build the higher pressure fuel system. 2000 operates at 60 psi - the 1995 was at 15 psi. And fab up some exhaust.
BTW - no one ever swapped in an LS for $1500. With friends in low places and some wheeler dealing maybe $3000.
Not trying to discourage you. Just trying to help you see what you are thinking of attempting.
The best thing you can realistically do is find another 89-95 vin Z 4.3. might take a while to find a good one as they're getting scarce. One from a full size pickup or van that's also a vin Z will work.
