I own a 1997 Chevrolet Blazer. I was unlucky enough to have the trans cooling line pop out of the radiator and spray hot ATF on my engine.
This causes a minor fire and melted alot of connectors and such. I purchased an engine harness from a 96 blazer. I did not change the harness yet because none of the wires were cut, just that the insulation was off.
I temporarly isolated the wires with electrical tape and checked everything. I attempted to start the car but no crank. All the lights are lid on the dash but no crank.
I have a remoter starter alarm installed but the alarm should be disabled since it doesnt go off.
My questions:
Is the wiring harness from a 97 same as the 96 one? I noticed somewhat different A/C plugs, but i might be wrong.
How can i check if the starter is still good and find out if the alarm is interupting the starter circuit.
Thanks for your help.
My questions:
