Status
Not open for further replies.
1 - 20 of 42 Posts
Sold :'(
I've searched many forums over the past couple hours and have found nothing definitive. I'm trying to find accurate measurements of S10 axles, not "I think it's about xx inches wide". I need to know 2WD, 4WD and ZR2 widths from WMS to WMS. A guy has an 8.5 (or 8.625) with G80 from his ZR2 for sale for $150. I figured it's a decent deal if I could use it on my 2WD. I planned on using a 4WD rear for more track width, and using spacer adapters in the front to widen it the same amount over stock. I need to know the definite widths of these axles so I can determine if the ZR2 axle would be excessive, and if I should stick to the regular 4x4 axle.
Super Moderator
I forgot stock EXACT measurement but I know where to find it,
But basically.
4wd, 2" wider per side than 2wd
ZR2 4wd, 4" wider per side than 2wd.
Super Moderator
Here you go.
2wd 54.5"
4wd 59"
ZR2 63"
**** New Jersey
yea, i knew the 4x4 and the zr2 rears. didnt know the 2wd.
Sold :'(
The wheels I'm using are 17x8 with 0 offset (4" BS). I'm thinking that I'll like the width of these wheels on a ZR2 axle, but the front will require an LT kit and a spacer. I need to see a pic of low-offset wheels on a ZR2, and I figure there's more of a chance of finding a ZR2 with ZQ8 wheels for reference. So, would anyone know where I could find a pic of ZQ8 or Xtreme wheels on a ZR2? Or maybe a forum with someone on there that has such a setup and I could hound them for pics? What would be the widest spacer one would consider "safe"?
Super Moderator
NP, send the 750mL whiskey to me lol.
You can buy LT from any fabbers on dezertdimes.com, getting it 3.5"-6.5" are doable with coil-coilovers and with that rim and backspacing, you may not need spacer.
Once you get LT taken care of then you'll be able check if you'll need spacer or not.
Super Moderator
3.5" - 6.5" wider per side*
Sold :'(
Discussion Starter · #9 ·
I want to keep everything in factory proportions, just wider. So, if I use that ZR2 axle, my rear wheels will stick out 4.25" further than where they're at now. I'll need 3.25" longer arms if I use AIM spindles and 2.25" if I use Fabtech spindles. I don't think I'd mind a 2.25" spacer, so I could save the money I'd spend on an LT kit and put it towards the more expensive Fabtech spindles. I just don't think I'd wanna use a 3.25" spacer, that just kinda scares me.
dumb question.....
but can you do that to widen your stance up front? Just make like 2 inch wider arms?
Zr2.2
dumb question.....
Yeah that's all the long travel suspensions do, longer control arms equal longer range of travel. Your lookin at big bucks though just for a wider stance.
Cheap and easy is a set of wheel adapter/spacers. Not the best solution if your hard on it, but it's the cheapest and easiest way to widen the stance.
Sold :'(
Discussion Starter · #12 ·
Well, I ended up with a set of Fabtech spindles because I got a package deal on them. And, I have the ZR2 axle. AND, the wheels I'm using are 8" wide with 0 offset (4" backspace). So, my rear wheels will be moved outward a grand total of 4.58" per side from where they're at now (I have stock Xtreme wheels on it now). So, accounting for the 1.5" the spindle will give me and the .33" the wheels will give me, I'll need 2.75" more width in the front to keep my factory proportions. If the AIM LT kit is 2.5" per side, then I think that'll be close enough. If I find that I'm missing that .25", I'll get longer studs and a .25" spacer.
What do you mean by "hard on it"? Would you say that I should be fine with ~2" spacers on stock CAs if my truck is on paved highway 98% of it's life? BTW, my tires are 255-75-R17, so a tick under 32".
Zr2.2
I'm thinkin hard on it as in offroading hard. The spacers would put added stress on the wheel bearings because of the tire being further out and adding leverage. As for road driving it, I'd see no problems, at least no problems for quite some time(still could wear on the bearing in time).
The lowered guys use spacers all the time to fit vette or front wheel drive wheels, and I havent read much dislikes from them. I'd just get some new wheel bearings just for the heck of it, they are cheap enough. I know 992drjimmy ran 2" spacers in the front with no issues while he had his lifted truck, a couple other guys have also. I'm going to get some spacers when I get my tax returns back, most likely just 1.5" just to even the rear up more with the front. I'm gonna put them in the front and see how it looks for sure.
well bill, you wanna get me a set too haha
Zr2.2
Sold :'(
Discussion Starter · #16 ·
Well, I feel better about the spacers. Maybe I'll try 'em out for a while until I can save the cash for the LT kit. I just got new bearings and races when I did my front brakes about two months ago, so I should be okay. I'm also gonna get a full set of Power Performance BJs. I guess I should order them now so I'll have a better chance of getting them by summer!:rolleyes:
BTW, Fabtech's instructions for the spindles says:
WHEEL SPACERS MUST NOT BE INSTALLED WITH THESE 3" LIFT SPINDLES!
Is that to prevent excessive wear to the bearings and/or BJs, or is it because the spindles could break (spindle separate from the knuckle, etc)?
all three.... I have std S10 2wd can i put a 4x4 rear end in my truck without modification? wut years had the widest?
Sold :'(
Discussion Starter · #18 ·
The year of truck really had nothing to do with the width of the rear end, except for the years that ZR2s were made. And, yes, a 4x4 rear end will be a direct swap for your truck. What? listed the different widths in the third post of this thread.
Zr2.2
Covering their backsides. They also say don't use wheels with different offsets. Basicly you can't sue if you break your truck or kill yourself using the part "improperly". If guys can jump trucks with these spindles, I don't see how putting a spacer on it and driving around town is going to hurt anything. Heck I have watch stock trucks launch 4-5 feet off the ground at the sand dunes over and over with no parts breakage. The spindles are way heavier built then stock for sure.
Check these..
http://cgi.ebay.com/ebaymotors/5x4-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Sold :'(
Discussion Starter · #20 ·
I figured as much, but wanted to hear someone's experienced input.
I was wondering if anyone made hub-centric spacers. Thanks for the link. I can slip a $70 purchase by the wife much easier than an $800 one!
1 - 20 of 42 Posts
Status
