i was just curious, what is the easiest way to remove the emblems on my truck. Hopefully without screwing it up? :confused:
Yeah, still on the bottle
They peel right off... just be careful when doing so... There's no special way of doing it just don't use anything metal on it. Use a plastic razor with a good wide blade and slowly go behide it.. afterwards use a "Goo-off" to remove the stickey stuff...
"GOT RICE?"
I found it easiest to use a heat gun or blow dryer on low-med heat to warm the glue up first and then most of it comes of all together.
i used a blow drier and a puddy knifee... i carefully went between the glue andd the truck ... and got the rest off the glue offf with a rag and goof off =)
pimpslappin midgets
cutting torch and a jackhammer, it shoud come right off. Seriously blow drier and my fingernails did the trick for me
