has no indigoblue2kdime.
2 questions
1. when im in neutral slowing down from like 55-60, my headlights often 'blink' get real dim almost to the point of being off, then brighten up again, it does this a couple times until i stop. it also isnt consistent, seems to do it whenever it wants to
2. something inside my truck makes a 'whirr' sound, sounds electrical (like a bad ground in a radio someone told me) but it happens all the time, regardless of radio being on or not. it also increases with the rpms (like a turbo :p )
so if anyone has any suggestions or ideas as to what this might be it would be greatly appriciated... thanks in advance
PUNISHING GROUNDS
Could b ur alternator goin out. A buddy of mine got a whirl sound like a turbo comin thru his speakers...n thats what it was...alt was going bad.
hmm that could be it actually
would probably explain the headlight blink too i suppose...
is there any way to test your alternator?
Damn right I'm a maniac.
:stupid: Sounds like your voltage is fluctuating at idle, which would most likely be a bad alternator. I think autozone will check it for free.
