Hello, i'm new to the forum. This is my first post.. Yay!
I have a 1992 S-10 with a 4.3L engine, and it is having issues when firing.
I replaced the ignition coil, and the pick-up coil on it less than a week ago. What happens is.. if I leave it for a while it starts right up, but I guess if it's hot it won't start. (It's getting no spark) If I turn it off when it is running, then start it right away it will start, but if I leave it for a minute or two and try to start it, it won't start.... so basically sometimes it starts sometimes it doesn't.. lol.
ΜΟΛΩΝ ΛΑΒ&
First off, welcome to the site...
Secondly, Internet diagnosis is often times impossible
Third-ly I would check the ignition module and the ignition switch, both known to cause that problem
F.ound O.n R.oad D.ead
welcome to the forum. wish i could say more but i have on idea what it could be. hopefully youll get some good insight in afew
Hmm.. I could see it might be the ICM, possibly even the switch. I'll give that a try and let you know.
Thanks
You were right, it was the ICM started right up! Thanks for the help!
