Since I'm not happy with the Dashtop interior door panels I bought, I've found some nice 1st gen panels on Facebook, but they are electric. Can I change them to manual by replacing the insert around the door handle/window lock ? Or is it actually shaped differently. Of course a hole would need to be drilled for the handle too. Thanks !
Premium Member
1994 GMC Jimmy SLE, 2010 Cadillac STS
They’re the same, if you are comfortable with melting the plastic tabs to separate the panels and put them together you can, I just used a hole saw to put the handle through.
Looks like my inserts are just held in with metal clips. SO..........maybe no melting ? Or, maybe the clips are a PITA to remove ? Thanks !
