I've got an '85 w/ 2.5 iron duke and i want to swap in a quick ratio steering box. Got the box, but my truck doesn't have power steering, and that's definitely needed for the quick ratio. Mounting a power steering pump has 2 problems: first, I can't find any brackets for the 2.5; and second, it will suck power from an already feeble engine. So I'm wondering, has anyone done or considered doing electric power steering? Seen a couple Youtube vids on DIY from a Prius and Saturn EPAS units into some old cars & pickups. Looks slick, but the devil's in the details.... Any advice?
time to get cereal
Hydraulic power steering doesn't suck power, trust me, I went from power to manual and there is no power difference. Just get the bracket off of a truck at the junkyard and buy the pump hoses for it.
Also, if your quick ratio box is made for power steering, you should really have it hooked up correctly.
2.5 w/ power steering - been unable to find any in the junk yards.
What do you mean "should really have it hooked up correctly"? Yes, the new steering box is for power steering.
time to get cereal
Then you should have the hydraulic system hooked up... Electric power steering is not hydraulic.
time to get cereal
I think it was 24:1, about 6 turns lock-to-lock. The effort was fine with 205/65r15s, it was slightly harder to steer with 245/45r17s. You just have to get it rolling a little bit before turning the wheels, don't steer with the vehicle stationary.
Also, make sure your alignment is good. Bad caster settings will make the steering harder.
