Ok i put the 350 in my s-10 and my mechanical fuel pump hits the frame. so i want to put in a electric pump. Any recommendations for a cheap pump (on a major budget). I have a holley 4bbl 600cfm carb, not sure if that matters or not. How much psi will the pump need to put out? I am using the jtr engine mounts and i thought that the fuel pump wouldnt hit and i am sure we welded them up correct.
i'm about to install an electric fuel pump in my truck now.... Holley red label.... Jegs part number 510-12-801-1 with a safety swich 510-12-810 . Yes, the pump is loud, and when you stop at a light you can hear it run.... but if it's running, its likely running :D that's always a plus in my book!
i've also heard of people promoting an edelbrock, but i dont have a part number on that one.
hope it helps!
chris<pixelmonkey>
