NO no no. If it's a TBI, then its mounted on the intake manifold behind the throttle body.gpwrastler said:if my mem. is right its to the left of the alt? and in is about 4 inches tall and about 2inches wide (cylinder) and 2 bolts hold it on just unplug the wires and it has 2 holes one open and another with what looks like a torx screw in it and just get brake cleaner and shoot it up in there to where it move free not sure about cost check autozone.com
shit i was think of my 9691S104x4 said:NO no no. If it's a TBI, then its mounted on the intake manifold behind the throttle body.
Right. I used carb cleaner and a tooth brush to clean mine. If you can get ahold of a screened gasket they work well. There is a screen covering the openings so that carbon chunks can't get stuck on the valve keeping it open.91S104x4 said:NO no no. If it's a TBI, then its mounted on the intake manifold behind the throttle body.
ask and ye shall recieveMike1234 said:Right. I used carb cleaner and a tooth brush to clean mine. If you can get ahold of a screened gasket they work well. There is a screen covering the openings so that carbon chunks can't get stuck on the valve keeping it open.
