1 - 20 of 66 Posts
· Premium Member
You might have better luck if you include (as basics) the engine size and year, along with what you consider "best most cost effective".
· Awww..you ain't got shit!
1984 S-10. Modified
86 carbed will require the older 82-85 distributor with vacuum advance. Rockauto has them. Last one I bought was about $60 if I remember right. There's literally no real advantage to some "race" distributor. HEI will work just fine.
1984 S15 2.8 5 sp
Reactions: jimmykicker
1984 S15 2.8 5 sp
What the ****… so mechanical wouldn’t work?
Distributors with the vacuum pot have both mechanical and vacuum advance.
The one you bought will work, just work like crap with flat spots on the acceleration curve.
Sent from my iPhone using Tapatalk
1984 S15 2.8 5 sp
RockAuto didn’t have one that you suggested… can you point me in the right direction?
They did when I bought one last month; I guess I got the last one. ;) Keep checking.
Check FLAPS, GMPartsdirect, and eBay for used, as well as junk yards.
1984 S15 2.8 5 sp
I have looked around I can’t seem to find one… I’ll just use this one and out a D.U.I coil on it
How is a new ignition coil going to variably affect ignition timing?
1984 S-10. Modified
Yeah man, I am sorry about that. You definitely need the vac advance one. Look at 1982.
Font Screenshot Rectangle Automotive tire Software
1984 S-10. Modified
I will say that RA is showing that electronic distributor for 85, I suppose CA trucks had them?
Discussion Starter · #20 ·
DUI would take too long and real expensive lol… I just want something that will have it run well right out of the shop! So if you can let me know which one I’ll return the one I bought and go from there.
1 - 20 of 66 Posts
