1 - 16 of 16 Posts
tits
Well, I've been goin at my truck for the past 2 hours trying to get the decals off, got from the driver rear panel up to the door, and I still have to do the door. And after doing that much, my fingers have started to bleed. ANyone got any reccomendations to make this easier?
SVT Cobra Moderator
let glue remover sit on it and take a string and use it like a saw under and cut off then get the rest of the glue off
I have a Civic now
:stupid:
you are trying to get the emblems off?? i just used fishing line like offthehook said, then some release agent/adhesive remover to get the rest off the glue off, it will take some time, then you need to wash it good, then wax! Good luck.
tits
No not emblems...decals that come stock on some X's. The ones that start in the front panels and go near the rear fenders.
I have a Civic now
Just use a heat gun and peel, you dont need to get it real close either, my 01 blazer had some cheesy ass decals that the dealer put on and i easily took them off, just go slow and use some adhesive remover to remove any leftover glue.
I have a Civic now
ready247 said:
be carefull with a heat gun u can blister the paint quick, try your mom or your sisters hair dryer you will be hard pressed tp damage it that way......plus not everyone has a heat gun:werd:
True i seriously kept mine a good 12 or more inches away and kept it moving, i bought i cheepy one from Lowes, was like 10 bucks, for paint and wallpaper uses, i used an industrial one for my truck tailgate a while ago and that sucker did burn a hole in my paint, lol, be careful.
It worked for Superman
you guys must have some cheap paint. I used an industrial heat gun to take off my side molding and I held the heat gun in one place for like 10 seconds 2 inches away and nothing happen to my paint. I think you should give your paint a little more credit. The auto paint these days is some tough stuff.
tits
Discussion Starter · #11 ·
Forgot I had this post up. Heat gun did the trick!!! Thanks guys!
at bodyshops they use eraser wheels attached to low speed drills. you can get these from auto zone or murrays for $10-15 and its just a big eraser that rips the decals off without damaging the paint. pretty neat
Yeah, I'm a bodyman and we use the eraser wheels. You can turn 'em pretty quick too. They won't come apart. They also take off ALL the glue too!! NO mess.:headbang:
you sure your not using a torch?.... lol:p
Pressurized 2.2 Member
I used a old credit card worked great no decals no pinstirpe no chevrolet on the back all clean now.
1 - 16 of 16 Posts
